User & Group Management
Early Access
This feature is currently in early access and will be fully available in version 1.5.0.
Users and groups are managed directly in the Cryptomator Hub admin interface. As an administrator, you can create, edit, and delete users and groups, assign roles, and manage group memberships.
Access the user and group management from the navigation bar in the admin area.
User Management
User List
The user list displays all users in your Hub instance. You can search for users by name or email and see key metrics for each user:
  • Number of accessible vaults
  • Number of group memberships
  • Number of registered devices
User list overview
Create User
To create a new user, click the "Create User" button in the user list. Fill in the following fields:
  • Profile Picture URL: Optional URL to a profile picture
  • First Name: The user's first name
  • Last Name: The user's last name
  • Username: A unique identifier for the user (cannot be changed later)
  • Email: The user's email address
  • Roles: Assign roles to the user (see Roles)
  • Password: Set an initial password for the user
Create user form
After creation, the user can log in with their credentials and complete the account setup.
Edit User
To edit a user, navigate to the user's detail page and click "Edit". You can modify:
  • First Name
  • Last Name
  • Email
  • Roles
  • Password (set a new password)
Username cannot be changed after user creation.
Delete User
To delete a user, you can either click the delete button in the user list or navigate to the user's detail page and click on the options button next to the "Edit" button, then select "Delete". A confirmation dialog will appear. Deleting a user will:
  • Remove the user from all groups
  • Revoke access to all vaults
  • Delete all registered devices
This action cannot be undone.
User Details
The user detail page shows comprehensive information about a user:
  • Groups: All groups the user is a member of
  • Accessible Vaults: Vaults the user has access to (directly or through group membership)
  • Devices: All registered devices of the user
  • Legacy Devices: Devices registered with older Hub versions (see Legacy Devices)
User detail view
Group Management
Groups allow you to organize users and grant vault access to multiple users at once.
Group List
The group list displays all groups with:
  • Number of members
Group list overview
Create Group
To create a new group, click the "Create Group" button. Fill in:
  • Profile Picture URL: Optional URL to a group picture
  • Name: A descriptive name for the group
Create group form
Edit Group
To edit a group, navigate to the group's detail page and click "Edit". You can modify the group name and profile picture URL.
Delete Group
To delete a group, you can either click the delete button in the group list or navigate to the group's detail page and click on the options button next to the "Edit" button, then select "Delete". A confirmation dialog will appear. Deleting a group will:
  • Remove all members from the group
  • Revoke group-based vault access (users may still have direct access)
Group Details
The group detail page shows:
  • Members: All users who are members of this group
  • Accessible Vaults: Vaults the group has access to
Group detail view
Manage Group Members
From the group detail page, you can:
  • Add Members: Click "Add Member" to search for and add users to the group
  • Remove Members: Click the remove button next to a member to remove them from the group
Add member dialog
Subgroups are not supported at this time.
Roles
There are three roles in Cryptomator Hub:
RoleDescription
userDefault role. Can open vaults and manage their own account.
adminCan manage users and groups, view audit logs, and create vaults.
create-vaultAllows users to create new vaults. Inherited by the admin role.
Roles are assigned when creating or editing a user. The user role is assigned by default to all users.
Create Vault Role
By default, only users with the admin role can create vaults. To allow other users to create vaults, assign the create-vault role to them when creating or editing the user.
User Avatars
Users can have profile pictures displayed throughout Hub (e.g., in vault member lists). As an administrator, you can set the profile picture URL when creating or editing a user.
The avatar can be provided as a URL to an image (e.g., https://example.com/avatar.png).
If no profile picture is set, a generated avatar based on the user's name will be displayed.
External Identity Management
Enterprise Feature
Connecting external identity and access management (IAM) solutions is available as an Enterprise feature.
Visit cryptomator.org for more information about Enterprise features.
Accessing Keycloak via Hub
Connecting Cryptomator Hub to an external identity manager allows you to:
  • Synchronize users and groups from LDAP or Active Directory
  • Delegate authentication via OpenID Connect or SAML
  • Keep your user management centralized in your existing IAM
You can access the Keycloak management interface from the admin section of Hub. There you can perform all user- and group-related tasks, such as creating new users, deleting users or managing groups.
Setting up LDAP synchronization is described in the Keycloak documentation. For OpenID Connect and SAML, the Keycloak documentation provides general information.
Regardless of your IAM setup, your Hub instance always contains two system users: admin and syncer. Do not edit or delete them! These accounts are required for administration and synchronization tasks.
