Working with Vaults
To encrypt your data securely with Cryptomator Hub vaults, you need the Cryptomator app for your OS. Cryptomator runs on Windows, macOS, Linux, Android and iOS. You can download the version for your OS from cryptomator.org.
This section describes exemplarily how to unlock a vault in the Desktop app. Android and iOS work analogously.
As described in open an existing vault, you should have already added the vault to the vault list, e.g., by selecting the vault.cryptomator file.
Unlocking a Vault​
1. Click Unlock​
To unlock the vault, click on the large Unlock button in the center of Cryptomator's main window.
Click 'Unlock' to unlock a Hub vault with the Desktop app
2. Authenticate​
Cryptomator should open your default browser for authentication. If you're not already logged in, you need to provide your user credentials, e.g., by entering your username and password or by inserting your key when WebAuthn is enabled.
After your browser asks for credentials, enter your username and password
3. Register Device​
If you connect to Hub with this device for the first time, you need to register it.
Desktop
Register your device by entering the setup code and a name for it
Hub
Hub shows the new device view during unlock
Enter a name for the device to identify it later on and the Account Key which was generated during the account setup. You can also find it in the account settings.
After that, you will see a confirmation dialog, unlock the vault again.
4. Vault Unlocked​
You are all set up and an unlock should be successful from now on. You can then reveal the vault's contents as usual.
Desktop
Desktop shows unlock successful
Hub
Hub shows unlock successful
