User Guide
This guide is for everyone who uses Cryptomator Hub to store and share encrypted data. It covers your own account, the vaults you own or are a member of, and how you unlock them with the Cryptomator apps.
If Hub is new to you, start with the Quick Start. It walks you from your first login to an unlocked vault. The other pages describe each area in detail.
Quick Start
From your first login to an unlocked vault — set up your account, create a vault, invite teammates, and unlock it with Cryptomator.
Your Account
To open vaults secured by a Cryptomator Hub instance, you need an account on the regarding Hub instance.
Vault Management
The central entities in Cryptomator Hub are vaults.
Working with Vaults
To encrypt your data securely with Cryptomator Hub vaults, you need the Cryptomator app for your OS.
Vault Recovery
This section contains instructions for recovering Cryptomator Hub vaults using the vault recovery key.
