User & Group Management
Users and groups are managed directly in the Cryptomator Hub admin interface. As an administrator, you can create, edit, and delete users and groups, assign roles, and manage group memberships.
Access the user and group management from the navigation bar in the admin area.
User Management​
User List​
The user list displays all users in your Hub instance. You can search for users by name or email and see key metrics for each user:
  • Number of accessible vaults
  • Number of group memberships
  • Number of registered devices
User list overview.
Create User​
To create a new user, click the "Create User" button in the user list. Fill in the following fields:
  • Profile Picture URL: Optional URL to a profile picture
  • First Name: The user's first name
  • Last Name: The user's last name
  • Username: A unique identifier for the user (cannot be changed later)
  • Email: The user's email address
  • Roles: Assign roles to the user (see Roles)
  • Password: Set an initial password for the user
Create user form
After creation, the user can log in with their credentials and complete the account setup.
User Details​
The user detail page shows comprehensive information about a user:
  • Groups: All groups the user is a member of
  • Accessible Vaults: Vaults the user has access to (directly or through group membership)
  • Devices: All registered devices of the user
  • Legacy Devices: Devices registered with older Hub versions (see Legacy Devices)
User detail view
Edit User​
To edit a user, navigate to the user's detail page and click "Edit". You can modify:
  • First Name
  • Last Name
  • Email
  • Roles
  • Password (set a new password)
Username cannot be changed after user creation.
Delete User​
To delete a user, you can either click the delete button in the user list or navigate to the user's detail page and click on the options button next to the "Edit" button, then select "Delete". A confirmation dialog will appear. Deleting a user will:
  • Remove the user from all groups
  • Revoke access to all vaults
  • Delete all registered devices
This action cannot be undone.
Group Management​
Groups allow you to organize users and grant vault access to multiple users at once.
Group List​
The group list displays all groups with:
  • Number of members
Group list overview
Create Group​
To create a new group, click the "Create Group" button. Fill in:
  • Profile Picture URL: Optional URL to a group picture
  • Name: A descriptive name for the group
Create group form
Edit Group​
To edit a group, navigate to the group's detail page and click "Edit". You can modify the group name and profile picture URL.
Delete Group​
To delete a group, you can either click the delete button in the group list or navigate to the group's detail page and click on the options button next to the "Edit" button, then select "Delete". A confirmation dialog will appear. Deleting a group will:
  • Remove all members from the group
  • Revoke group-based vault access (users may still have direct access)
Group Details​
The group detail page shows:
  • Members: All users who are members of this group
  • Accessible Vaults: Vaults the group has access to
Group detail view
Manage Group Members​
From the group detail page, you can:
  • Add Members: Click "Add Member" to search for and add users to the group
  • Remove Members: Click the remove button next to a member to remove them from the group
Add member dialog
Subgroups are not supported.
Roles​
There are three roles in Cryptomator Hub:
RoleDescription
userDefault role. Can open vaults and manage their own account.
adminCan manage users and groups and view audit logs.
create-vaultAllows users to create new vaults.
Roles are assigned when creating or editing a user. The user role is assigned by default to all users.
User Avatars​
Users can have profile pictures displayed throughout Hub (e.g., in vault member lists). As an administrator, you can set the profile picture URL when creating or editing a user.
The avatar can be provided as a URL to an image (e.g., https://example.com/avatar.png).
If no profile picture is set, a generated avatar based on the user's name will be displayed.
External Identity Management​
Instead of managing users and groups directly in Hub, you can connect Cryptomator Hub to an external identity provider (LDAP, Active Directory, OpenID Connect, or SAML) so users authenticate with the credentials they already have.
See Identity Provider for how to connect and manage an external identity provider.
