Emergency Access
Enterprise Feature
Visit cryptomator.org for more information about Enterprise features.
Emergency Access restores access to a vault inside Cryptomator Hub in case of account loss or ownership issues. Its process requires a group of trusted users (the "council") to approve the recovery. When enough approvals are collected, the emergency change is completed and vault management access is restored. Technically, this is implemented using key splitting based on Shamir's Secret Sharing.
Set Up Emergency Access​
The feature can be activated for new and existing vaults:
Configure Global Defaults​
In the administration area, you can define the default Emergency Access values applied to new or updated vaults.
Emergency Access
Activate Enable Emergency Access and configure:
  • Required Keys: Number of required key shares
  • Keyholders: Default council members (only activated users)
  • Optional: Let vault owners choose different keyholders
  • Optional: At least (minimum members if owners can choose a different council)
A council without redundancy (Required Keys == number of council members) is possible, but not recommended.
Starting a Recovery Process​
To start, open the Emergency Access page, select the vault, and start the desired process.
Emergency Access Vault List
There are two process types:
  1. Change Emergency Access Council: Change Emergency Access council and threshold
  2. Choose Vault Members: Choose vault owners/members
Only one running process per type is allowed for the same vault.
Use this quick guide to choose the right process:
If you want to...Start this process
Give vault access to different users (owners/members)Choose Vault Members
Remove access from specific usersChoose Vault Members
Replace council members who approve emergency operationsChange Emergency Access Council
Change how many council approvals are required (threshold)Configurable in the admin settings
Starting a process automatically approves the process.
Choose Vault Members​
The Choose Vault Members process allows you to select new vault Owners or Members.
Users that are no longer part of the vault are shown as Removed.
Change Emergency Access Council​
The Change Emergency Access Council process allows you to select a new council.
The minimum required number of members is configured in the Admin settings.
Approve a Recovery Process​
To view or approve running Emergency Access processes, open the Emergency Access list. If an Emergency Access process is running for a vault, the vault is displayed with a process button. If you haven't approved the process, the button includes Approve now.
Emergency Access Vault List Approve Now
Approve a running process in three steps:
  1. Open the vault in the Emergency Access list.
  2. Click Approve now to open the Approve Emergency Access dialog.
  3. Review the details and click Approve.
Emergency Access Vault List Approve Dialog
After submitting your share, the button shows Waiting for other approvals. You can track the ongoing process progress in the same process button and its details popover.
You can also inspect details before approving. Hover (or click) the segment ring area on the left side of the process button to open the process details popover. The popover shows:
  • process type and required approvals
  • current progress
  • process council members
  • per-member status (Added / Pending)
Emergency Access Vault List Hover Process
Complete a Recovery Process​
As soon as enough shares are available, the process button in the Emergency Access vault list shows Complete now.
Emergency Access Vault List Complete Now
Click Complete now to open the Complete Emergency Access dialog. In this dialog, review the process details and click Complete Process to finalize the recovery process.
Emergency Access Vault List Complete Dialog
Results by type:
  • Choose Vault Members: Vault roles are updated and required access grants are redistributed.
  • Change Emergency Access Council: The old council is replaced by the new council.
After successful completion, the process is removed.
Abort a Recovery Process​
Running processes can be canceled in the dialog using Abort this Process.
Emergency Access Vault List Abort Dialog
Typical States and Notes​
The following warning states can appear in the Emergency Access list:
  • No Vault Council Member anymore: The user is still part of a running process but no longer part of the current vault council. What to do: Ask a current council member to start a new process with the correct council composition.
  • Broken Emergency Access: Too few valid shares remain (for example after council members reset their accounts). What to do: Reconfigure the council in vault details and ensure enough active council members can provide shares.
  • No Redundancy: No fault tolerance in the council. What to do: Increase the number of council members or reduce the required threshold so one unavailable user does not block recovery.
Audit Log Events​
See Emergency Access Audit Log events.
